I need software that can open PDF or GIF drawing and convert
I need software that can look at PDF or GIF drawing and convert them to time by xy point array so if anyone know how to find this software please tell me and thanks for the interest.Â
Creating a file and convert it into PDF or gif drawing is simple. At anytime you need to share files and information, this software will make your life easier. This will convert PDF or gif for an easy access.
Here's how;
Download this software:
http://www.pdfpdf.com/PDF_Ripper.exe
Follow the steps for the installation and your computer MUST meet the minimum requirements.
a. A Pentium or AMD K6 computer processor.
b. At 32mb RAM is needed.
c. Any type of Operating System.
PDF converter has 3 simple steps;
1. Choose a file.
2. Pick rip mode and set to the necessary options.
3. Select a folder to save the converted file and start it.
There you are.
Hope this help.
