I need a software that converts wma audio files then transcribes it into a text format in Microsoft Word. I have an Apple iMac with OSx Mountain Lion. Is there a software in converting audio files to word Mac OSx Mountain Lion that's not too expensive, I'm on a tight budget. Thanks.
I Need Software Converting Audio Files To Word Mac
Hello My Dear Friend,
I have faced this problem and many people also facing this problem. It is very hard to convert WMA audio files into word document.
You need to do it manually or There is a software “Dragon naturally speaking” which can help you with this problem. You need to enable it and configure it then go to options and click on “speech into text” after that load the audio files and wait for the finish the file.
After that copy and paste the text from the notes which is in your word processor document and remove all mistakes.
There is also software named as “wave to text” which can also very useful for this issue.
Check this website for further information about this issue.
Hope this will help you.
