I need a software for JPG date taken
Hi everyone,
I am working with JPG files. I am looking a software for JPG date taken. Can anyone know where I can find it? Please send me some links on it.
Hi everyone,
Hi Raymond Date and time in modern digital photos is stored in metadata in a part of the image called the EXIF. You can follow the following steps to add a time stamp to a jpeg image from the EXIF 1) Download image formatting software Imagemagick from this link 2) Once it is installed, open a command shell from Start the run and then type “cmd” then press enter 3) In the command window switch to the directory where your photo is stored 4) In the command window replace “Youre_test_photo.jpg” with the actual photo you want to test and “output.jpg” with your preferred output name 5) Then type in the following command convert “your_test_photo.jpg”-font “Arial”-point size 72-fill white-annotate+”100”+”100”” %[exif:DateTimeOriginal] output.jpg”
