alven
10 points
Posted on - 11/03/2011
Hello!
Can someone guide me please….
I carry out translation; my work involves word documents that use predefined styles.
The most common style is one that has each text formatted paragraphs.
This assigns numbers to individual paragraphs among other things.
Consequently over 90% of the text comprises of paragraphs that are numbered. Â
I need a tool that navigates directly to required paragraphs when need arises.
For instance if a translation contains paragraphs 1-300, I am able to move straight to paragraph number 95 from paragraph number 246.
How possible is that?
Thank you…
luasna
I need a software like ms word that fits my need
Hi
It's a difficult job if you do this one in MS-Word and that's why you might have searched for a new one.I think you can go to certain line directly from MS-Word 2007
And as you wish to number all the paragraphs and want to go directly from 95th paragraph to 246th using a MS-Excel software.You can enter all the paragraphs using a number column.And also it will be very easy to go from one paragraph to other.
And also you can do more operations using MS-Excel like translations in one
column and the real script in one.
Hope this could have helped you and don't hesitate to ask any further questions
luasna
