Hello! I have been working with SolidWorks and I feel that every time the process is very slow due to the fact that it opens many parts. What I need is Solidworks transform assembly at part so that I can work faster. How do I go about the conversion? Your assistance will be highly appreciated.
I need Solidworks transform assembly at part to increase processing speed.
The 2D Sketch can be brought from outside sources. You can also construct in SolidWorks but take note, it must be a single sketch from part document.
Though it must be from outside sources, you can copy drawing from documents or you can copy from outside sources directly into a 2D Sketch in part document.
You can edit, sketch, align or copy other features using tools.
