Hi guys,
I need some acrobat script calendar example.
Can you provide an illustration that shows an acrobat script calendar example?
I want to get some idea from you experts.
I wish you would take time to help me.
Expecting some help,
Thank you.
Well Mr. Davy,
Acrobat scripts are usually Java based scripting. So you can use a Java script like “var RightNow =new date ();”. There is a site acrobatusers.com can help you a lot.
Acrobat calendar script also deals with time.
Day count and day name can be included or you can modify as you like.
So take a tour in the given site hope you can find out the solution as you want.
