Hello experts,
I need some code convert jpg to plt. I just downloaded a converter that is capable of converting jpg to plt files or format but the problem is the software that I just downloaded is needed to get a code or shall I say an activation code for it to run, but I don’t have any idea where to get it. Please help me and share with me your solutions regarding this matter. Thank you.
There is no shortcut way to convert the files as both formats are different in structures.
One is in image format and another is in code format. Try the CAD converting tools for converting those files.
First convert the files into vector format. Then convert it as .plt format through Autocad.
https://fileinfo.com/extension/plt
Hello Jessica,
To convert jpg to plt install Total CAD Converter then press the JPEG icon in the top menu and click Start in the new window to start converting with the default settings. To set the destination folder, crop, rotate, or change files, select the appropriate files before clicking Start.
Thanks
