Hello
I am new to the open source community. I currently use Ubuntu 11 operating system. I heard about the SWT open source applications gallery, so I like to test it. I need to know how to get it, and what are the features available in it.
Thanks
I need some details about the swt open source application gallery
Hello Mary,
If the SWT are open source applications, then you can download them for free from the internet. All you will need to do is go to Google or your favorite search and then look for the applications with the right specifications that you have in mind. Or you can go to the developer’s website and download it from there.
Nicke
Hello Franke,
SWT (The Standard Widget Toolkit)
It's a Java designed open source widget toolkit. It's implemented in the operating system to provide efficient, portable access facilities.
Here are the features of SWT:
Eclipse forms new in 3.3
Swing Integration
Simple image effects
Custom drawing table and tree items.
Virtual tables and trees
Open GL
Option to view HTML page.
Basic image viewer
Drag and drop function.
Styled Text widget
Active X support
You can create your own widgets.
Hope this would help you.
Thank you.
