I need some explanation about php session
I'm looking for some help regarding PHP sessions,I am new to PHP,
Please anyone can explain me how sessions work,
How do they help us?
PHP application uses sessions and it will be used when a user was in the point where his or her website needs to pass to the user data from a page to another. The usual HTML website do not pass data from a page to other PHP session and this can be resolve by letting the user to store information on the server for future use.
This session is temporary and commonly removed instantly just after the user left the website that utilizes sessions. Session works by making a UID or Unique IDentification number on every visitor and will save variables depending on the ID number.
This way, it can stop two users data from having conflicts with each other when they visits the same webpage.
When you are working with an application, you open it do some changes and then you close it. This is much like a Session. The computer knows who you are.
It knows when you start the application and when you end. But on the internet there is one problem: the web server does not know who you are and what you do because the HTTP address doesn't maintain state.
A PHP session solves this problem by allowing you to store user information on the server for later use (i.e. username, shopping items, etc).
However, session information is temporary and will be deleted after the user has left the website. If you need a permanent storage you may want to store the data in a database.
Sessions work by creating a unique id (UID) for each visitor and store variables based on this UID. The UID is either stored in a cookie or is propagated in the URL
Example:
<?php
session_start();
// store session data
$_SESSION['views']=1;
<html>
<body>
<?php
//retrieve session data
echo "Pageviews=". $_SESSION['views'];
</body>
</html>
Output
Pageviews=1
Beshoy
Notifications
