Hi techyv,
I need some help about grading system using turbo c. I am using turbo c programming language to make a grading system application for my students. Unfortunately I can’t figure out the right code for the average computation part. I need some help programmers.
Hoping for your help.
From Your description I become to know that you are seeking for a suitable application of c programming for grading system. May be for some sort of technical problem you didn’t get complete satisfaction by using turbo c programming.
I think you can use Multipack C developing system 2.21.
You will get these features from this application:
Micro-IDE – a Windows-based Integrated Development Environment
Complete online documentation including C Tutorial
C Library Reference, Technical Manual
Support for all C Compilers included in package
Project Examples for each compiler
GNU ARM C Compiler
DCC – a freeware optimizing.
I think you will be solved soon.
