Hello everybody,
I need some help on creating calculator GUI source code.
The graphical user interface is one of the most relevant parts of the program or system.
The GUI needs to look presentable so that the users will be more interested in the content.
Discuss with me on the best programming language that perfectly fits the system.
Thanks and have a nice day.
I need some help on creating calculator gui source code.
When the GUI becomes an important factor of the software you should always use a high level programming language like C#.NET or JAVA.
They provide you some high level built in libraries which makes your programming task much easier and they also support windows based applications. On the other hand,IDEs like Netbeans or Visual studio got high level and user friendly controls as well.
So I recommend you to use C# or JAVA as your programming language.
Code for C# development, JAVA development.
Hi Mellisa Wright,
You can use this example to create a simple Calculator using Java programming Language GUI:
import javax.swing.joptionPane;
Public class calculator{
public static void main(string args[ ] ) }
int sum= o;
String ans = " ;
int number = o;
Ans = joptionPane. showInputDialog (null, "Enter a number please:" ;
for ( int i = 1; i < number;i++)
sum+ = i;
joptionPane.showMessageDialog( null, "the total sum of the numbers is =" + sum);
Java is the most popular languages overall. Most popular languages for beginners to learn ,,
Enjoy.
