ave broers
70 points
Posted on - 12/03/2014
How can I format my data in the worksheet in Excel? Is there a way to apply the same formatting to all worksheets in the workbook? How do I do this? Is it possible to eliminate certain sheets when I do this?Are there quick styles available in Excel like in MS word?
I need some help in formatting data in Excel
There are multiple ways to format your data in the worksheet depending on what you wanted to do. If you want to apply the same format to all worksheets in the workbook :
Ctrl+click the tabs of the sheets on your worksheets to group it all together, and the tabs will turn white. after sheets are grouped, anything you enter in one sheet will also apply into the others.
