I need some help with my Macintosh
I need some help with my Macintosh, I can’t enjoy it because I can’t install adobe flash player. When I launch its installer, an error prompt saying "adobe flash player quit unexpectedly" pops-up. Some applications such as the DVD player won’t work but that is not my main concern.
The installed graphics drivers seem appropriate, as such, effects such as the transparent menu bar and water ripple effect are still able to run. Does this mean that this isn’t a graphic related issue?
System info:
Processor: AMD FX 4100
Motherboard :Â 990FXA-UD5
Graphics Cards(2):Â GTXÂ 560Â ti
RAM: 16 GB
Error report:
Code:
Process: Adobe Flash Player Install Manager [1861]
Path: Volumes/VOLUME/Install Adobe Flash Player.app/Contents/MacOS/Adobe Flash Player Install Manager
Identifier:Â com.adobe.flashplayer.installmanager
Version: ??? (???)
Code Type:Â X86Â (Native)
Parent Process:Â launched [124]
Date/Time:
OS Version: Mac OS X 10.7.3 (11D50)
Report Version: 9
Interval Since Last Report:Â Â Â Â Â 7365Â sec
Crashes Since Last Report:Â Â Â Â Â 723
Per-App Crashes Since Last Report: 5
Anonymous UUID:          Â
Crashed Thread: 0
Exception Type:Â EXC_BAD_INSTRUCTIONÂ (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Thread 0 Crashed:
0  dyld                0x8fe3138d _sysenter_trap 3
1  dyld                0x8fe0d1e6 dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*) 372
2  dyld                0x8fe0d063 _dyld_start 51
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0xffffffe4  ebx: 0x00000002  ecx: 0xbffffc5c  edx: 0x8fe30b8a
  edi: 0x0000c000  esi: 0x8fe30a05  ebp: 0xbffffc68  esp: 0xbffffc5c
  ss: 0x0000001f  efl: 0x00010246  eip: 0x8fe3138d cs: 0x00000017
  ds: 0x0000001f  es: 0x0000001f  fs: 0x00000000  gs: 0x00000000
  cr2: 0x8fe3138a
Logical CPU: 0
Binary Images:
0x8fe0c000 – 0x8fe3eaa7 dyld (195.6 – ???) <3A866A34-4CDD-35A4-B26E-F145B05F3644> /usr/lib/dyld
External Modification Summary:
 Calls made by other processes targeting this process:
   task_for_pid: 1
  thread_create: 0
  thread_set_state: 0
 Calls made by this process:
   task_for_pid: 0
  thread_create: 0
  thread_set_state: 0
 Calls made by all processes on this machine:
   task_for_pid: 1123
  thread_create: 0
  thread_set_state: 253
VM Region Summary:
ReadOnly portion of Libraries: Total=280K resident=188K(67%) swapped_out_or_unallocated=92K(33%)
Writable regions: Total=8368KÂ written=12K(0%) resident=20K(0%) swapped_out=0K(0%) unallocated=8348K(100%)
REGION TYPEÂ Â Â Â Â Â Â Â Â Â Â VIRTUAL
===========Â Â Â Â Â Â Â Â Â Â Â =======
Stack               64.0M
VM_ALLOCATEÂ Â Â Â Â Â Â Â Â Â Â Â Â Â 4K
__DATAÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 172K
__LINKEDITÂ Â Â Â Â Â Â Â Â Â Â Â Â Â 76K
__TEXTÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â 204K
mapped file             200K
shared memory             12K
TOTALÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â 64.7M
