I m using PHP and I m having troubles while creating advanced PHP tabs, I want to make several PHP tabs created on a single page in such a way that when you move the mouse over the tabs the text appears below, can anyone help please? Is there any software for creating Advanced PHP tabs?
I Need some help regarding Advanced php tabs
Yes there is. What you need is ApPHP tabs. This contains PHP scripts that generates multi-level tab menu control.
It is also AJAX enabled and can display images, HTML and script files once you hover on the tab.
If you are a beginner in programming, you do not have to worry about complex codes because ApPHP contains easy and readable codes for developers.
Get this PHP script for only $22.95 by clicking this Yes there is.
What you need is ApPHP tabs. This contains PHP scripts that generates multi-level tab menu control. It is also AJAX enabled and can display images, HTML and script files once you hover on the tab.
Get this PHP script for free by clicking this link.
