clark son
30 points
Posted on - 01/27/2013
I am having troubles in splitting CSV files mac, on mac OS there are some large CSV files which are opening.
I want to split those files, I have tried to split those files through Excel but it's not working,
I want to know about any software that can split CSV files on mac.
Does anyone know of a CSV file splitter for mac?
Please tell me?
I need some help regarding splitting csv files Mac issue
Hi there Clark,Â
I don't think there are some available software's for you to use so far but this issue can be solved with no software needed, all you need to do is learn some basic Linux commands like split.
As a Linux expert you need to follow these instructions to get it sorted :
Open Terminal > CD /path/to/file (Go to the path of your CSV file) > split -l 400 file.csv newfile.csv
To check your new file line count do these commands :
WC – l < newfile.csv
I hope you fix your problem with this.
Waall MikeÂ
Hello!
If you want to split some file on your mac, you can easily download a software from the following link: File Splitter for Mac
You can use it to split csv or large text files. You have a 5 days trial period and after that, if you are pleased with it`s features, you can buy it or download it from another site.
I hope it helps! Good luck!
