Hello techyv,
I need some html help in mac. When making some html code program using notepad, as I open the safari browser in mac operating system to view my latest work. The browser crashes and there’s an error saying not responding. I always came up restarting the pc, do you have some ways to fix this error in the browser?
Expecting some help from you guys.
I need some html help in Mac.
Hi Mellisa,
I have read about your problem . I think so this is a simple problem . Two kinds of problem should be there .
1. The problem with  your operating  system .
2. The problem with  your safari browser.
First I give you the problem number 2 solution you have to uninstall the safari browser and also install the old version of Safari browser because of the latest version of Safari has many kinds of problem that the  cause we can use the old version of the safari it better than new .
If it cannot work you can change your operating system. That is a best solution of this problem.
Thank you
