I got my project for C programming language pointing on related lotto program in c. I need some exact websites wherein I can download a free sample codes that can generate lottery numbers. Or some other related applications.
Thank you experts.
I need some sample codes related lotto program in c
Hi Calvin Hoffman,
There are many codes available on the web for free. Have you tried to search it in google or in yahoo? Anyways I found a link just for you my friend try this https://www.daniweb.com/programming/software-development/threads/361127/lottery-game. The code uses stdio for the Library I hope you uses that too. But it’s okay it’s still the same with the iostream.h Library. I am using iostream.h in our C programming class I found it easier than to stdio.h Library.
Hope it helps. 🙂
