I need specific programmed software that kill processes
Our company has a large database which has many unimportant processes working in it. We plan to reboot the system but it will  be done later next year. As of the moment we need a software that kill processes which is programmed to stop unimportant processes that had been specified by our employees automatically when the system starts.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #194965
Hello
I think you are looking for Auto Kill Any Process 2.1. This app, as title says, kill any processes you manually specify. It can be used to prevent launching some processes or to scan your computer in order to kill any process which is launched, and you don't want it. It's very easy to use and it's free.
You can download it from here: http://www.softpedia.com/get/System/System-Miscellaneous/Auto-Kill-Any-Process.shtml
Answered By 0 points N/A #194966
Hi Meganwharding
Well you need to kill unimportant processes as fast as early.
I’ll recommend you software named “ProcessKO”.
It is usually for professionals and experienced users.
It is designed to kill quickly running or hanged process.
It does not need to be installed; it can execute easily from the Desktop.
It has one small portable utility for window PC’s and also a small usb stick.
I also detect automatically unimportant and defective process and kills them with user permission.
It supports OS windows 98 and latest’s.
I hope you will get this software as soon as possible to get rid of your unimportant process. Good Luck!
Jhonstoon Leen.
