I need an SQL rpt reader
Hello. What is a good SQL rpt reader? I'm trying to view an rpt report file in Microsoft Word 2010 but it just shows a bunch of codes. The rpt file came from SQL Server 2005. Can someone please help?
Hello Edward,
There are many SQL rpt reader used to view rpt report file. I think that the report Viewer pro is a good SQL rpt reader which I use. It is a professional grade crystal report viewer and complete rpt file viewer. It provides users to open, view, manage, run, refresh, print, email and export rpt and also rptr files. You can download this software and enjoy its wonderful facilities. Download Report Viewer Pro link.
Thanks
Taylor
You can use MS SQL Reader Software.
It is so improved and high quality software which views SQL database and MDF file. To download this software visits the following site.
http://soft.udm4.com/downloading/sql_rpt_reader/
Here you will get MS SQL Database Reader Software. Click on the link to download the software. You will get download button. Click on the download button to download the software.
