jelma demo
Posted on - 02/21/2013
I'm trying to create a stage light design on my Windows XP 64 bit PC. What is a good stage light design program using 3D CAD modelling? I need an accurate measurement of angles and distances from the program and controls the light from the PC. Thanks.
I need Stage light design program
Hello!
I think you can take use any of the following software to ensure good stage light design program using 3D CAD modelling: Lighting Level Calculator 3.0, Lightwright 3s, DecoTech Design Software 6.1, SketchUp 5 Film & Stage Library, Virtual Light Lab, and SketchUp 5 Architecture Library.
What's interesting is that you can get these tools free to use. Hopefully, you will enjoy them.
If there is any other problem, don't forget to let me know.
