I would like to compress a lot of files and I recently installed WinZip Mac Edition on my iMac that has a 2.7 GHz Intel Core i5, 8 GB RAM and OSx Mountain Lion. I'm having a "not compatible with OS" error. Are there any strong file compression for Mac?
I need a strong file compression for Mac
There are many software for compression.
You have downloaded the file compressor which is not fully compatible with the MAC Operating system.
There are many file compression software that are fully compatible with MAC Operating system.
I have searched the best file compression tools for MAC.
I have found 5 best compression tools.
You can download these compression tools from this link.
Download Best Compression Tools For Mac Operating system.
Thanks
