Stacey
Posted on - 11/01/2011
The following information describes my laptop: Dell Vestry 3400, 4 USB2 ports, 1 Sub/Sate port and 1 fire wire port. Now, I usually play my audio with my Audio Ionic U22, the track ball mouse and a keyboard; all via the sub ports. I also have an external Hard Disk Sate 2 and 4 USB1 ports Sub hubs. The issue I am having is a sub for my audio interface. Someone please help.
I need a sub port for my audio interface on my laptop.
If you want a different sub port for your audio, I suggest that you just buy a splitter type of wire in which you can have to different port but it is first attached to a single wire. You can also buy a speaker and then cut the other end of the wire and then attached it to that speaker. Then use another wire and have it attached to that same source or the other one and the attached it to a different speaker. It is pretty easy to do but I suggest that you just buy a splitter type of cord for audio just like your USB have for multiple ports.
