I need temperature monitoring plasma widget for my desktop
Hi experts,
I am looking for a plasma widget that can easily and accurately measure the temperature. That widget is required for KDE plasma desktop environment. I required temperature monitoring plasma widget. If you know or you are using any best widget, then share the information with me.
Regards
Best Answer by Ware Shaul
Answered By 270 points N/A #196737
Hello there Alberto,
I have researched temperature widget that might help you solve your problem.
This can be downloaded straight from seven forum's website which is actually created by one of the forum user. Download it and install it and share your inputs about it with the author. I hope this helps.
Waall Mike
Answered By 0 points N/A #134943
Hi Alberto,
There is a lot of plasma widget for temperature monitoring available in the market, however, some of them are not open source and hard to setup and configure. If you want to have a user-friendly, easy and accurate plasma widget, you can try customizable weather plasmoid. Kindly click the link below to review and download the widget.
To download the widget, please click the link: Customizable Weather Plasmoid
Ware
