I need template free Studio Pro
I have an iMac that has a 2.7 GHz Intel Core i5, 8 GB RAM, 512 MB Nvidia GeForce Graphics Card and OSx Mountain Lion.  I just installed DVD Studio Pro for creating my customized DVD video file.  Is there a template free Studio Pro?
Best Answer by Luke N Marks
Answered By 85 points N/A #193354
Hello
DVD Studio Pro has a few free templates for download here.
They can be used for NTSC or PAL videos.
They are compatible with DVD Studio Pro version 2, 3 and 4.
There are also theme packs available on the website which will allow you to download and install different elements which can be used to create your own custom menus.
Answered By 220 points N/A #193355
There are only few resources where you can get free studio pro templates. You may try these templates on this link:
http://www.dvdthemepak.com/dvdsp/free.php
On the other hand, DVD Studio Pro has its own built in templates already. You may explore it using these tutorials.
https://www.macprovideo.com/tutorial/menuTemplates
http://play.macprovideo.com/menuTemplates/1
http://play.macprovideo.com/menuTemplates/2
http://play.macprovideo.com/menuTemplates/3
