I was working on a Docx document when my PC crashed. It looks like the Word document I was working on got corrupted and I need a text recovery converter word 2010. Can I still recover information from a damaged document and will formatting be lost? I use Microsoft Word 2010.
I need text recovery converter word 2010
Hi Christine, I believe I will be able to formulate a solution to your question in the best way I can possible. Indeed you can be able to recover information from a damaged document and the formatting will not be lost because the program automatically saves the work done or at least a draft for part of the work that is done.
You can be able to find the software from the internet by searching from popular search engines like Google, Bing, yahoo, and most specifically you can get from the website; http://www.freedownloadmanager.org/download/text-recovery-converter-word-773276.html
This software is known as 'R-word recovery 1.0' but it works as effectively as the text recovery tool. It introduces a new utility that recovers and reconstructs the damaged Ms word documents.
The software extracts texts even from heavily damaged *doc files and never deletes damaged files from the disk. It writes to, or modifies the original document files when performing any operation including MS word document recovery.
Simply download it from the website and follow the indicated prompts to install.
Reboot your system and it should work well
I hope this helps
Thanks
Hello Christine,
Yes it is possible to recover text from the damaged file (Word file or a non word file). Since you need to recover the text from the word file so follow the simple steps:
1- Go to Microsoft Office word 2010.
2- Click on the button "Microsoft Office" and open it. You can also do this step by the File menu.
3- Here find "Recover Text from any file" and click it.
4- From the list select your document to recover your text.
5- Open it.
That will solve the problem.
Dear,
This is very easy to recover a text file from its corrupted state to working.
Here I am going to tell you two methods to recover your file.
1. Open Microsoft Office 2007 or 2010.
2. Click on office button on the head of program at title bar. It is also called control icon. When you will click on it, you will see a drop down list having many options
3. In this list look for “Recover Text” and select it.
4. Open this tool. It will help you a lot.
On the other hand, I suggest you that you go to the link download the software.
This software will also help you to recover your text.
