I need tips about Samsung remote control Galaxy Ace
Hi.
I have the Samsung Galaxy Ace S5830 that has Wi-Fi 802.11 b/g/n, DLNA, Wi-Fi hotspot, Qualcomm MSM7227 chipset, 800 MHz ARM 11 CPU and Android Gingerbread OS.
Is my Android phone capable of being a remote control for my WiFi enabled Samsung LED Smart TV?
Do I have to install anything?
I need feature tips about Samsung remote control Galaxy Ace?
Best Answer by Guzman Farlow
Answered By 0 points N/A #147334
Yes your phone can be used as to control your TV over a wireless network. NOTE: For this to work your TV must be an LED C-800 or higher.
To use your Samsung Galaxy as a remote you will need an app called Samsung Smartview app.
Therefore:
1 Download and install Samsung Smart View
2 On your TV select Setup > Find Wireless Remote Control
3 Connect your wireless Samsung LAN adapter to the TV USB port.
4 Connect your phone to the wireless adapter.
Launch the app on your phone.
Using the onscreen keyboard you can now control your TV from your phone and even stream live TV onto your phone.
Answered By 0 points N/A #147335
Hi Elias,
I have read about your concern with your phone Samsung Galaxy Ace  S 5830,You wanted to know if it has the capability to become a remote controller for your WiFi enabled Samsung led TV. Well it can and it is possible,you can turn your phone into a remote.
All you need to do is:-
Start by checking if the Samsung TV Remote App will work with your Samsung TV. because nearly all of the Samsung 2010 and 2011 models are easily compatible with the Samsung TV Remote App e.g LED C 6400 series and above,LCD C 650 series and above,Plasma C 6500 series and above. Then download the application in your phone from the Samsung App or the Android market.
And you need to be connected to the internet to do so. Data download and usage charges may apply. Also subscription charges may apply. You can control your TV settings such as ON/OFF function, channel navigation and volume control. The four way directional pad makes it easy to navigate your application,and the (QWERTY) keyboard allows you to input all the necessary information for your TV’s functions,controls and other Samsung App on the big screen. After downloading and installing the application now follow this steps to set up and control your TV.
1. Begin by going to set up on your Samsung TV's menu and look for wireless remote control. If you don't see this menu option then your TV is not compatible with this remote function.
2. Then simply connect your TV’s LAN port to your wireless router using a standard Cat 5 cable. You can opt to also connect the Samsung Wireless LAN Adapter to your TV’s USB port.
3. Finally make sure your phone is connected to the wireless router. And now it is ready for use.
NOTE:The external devices that are required to connect to the Samsung TV application and to the selected WIFI enabled TV are bought separately.
