Hi there. I have a 3D png file and an HD JPEG image.
How do I combine my png file with the JPEG file.
I want the JPEG as the background image to my png file.
I need tips on applying Background To A 3D Model In Photoshop.
I need tips on applying background to a 3D model in Photoshop
You can combine your PNG file with the JPEG file by putting the JPEG file in the background and putting the PNG file at the front.
If you get any problems while doing this, you can convert one image to a format that will fit well on Photoshop.
You can get tips on how to apply a 3D model in Photoshop at the adobe website.
You can also get more information on image formats at the photoshopessentials website.
It’s quite easy combining or mixing two images into one single image.
It’s only a matter of selecting which image is in the background and dragging which image on the foreground.
Try following these:
Open Adobe Photoshop and then open both images: the .jpg and the .png files.
After that, decide which image goes to the background. Since you want the .jpg image to be the background, select the .png image then click on the Move Tool found on the toolbar on the left of the interface. Or simply press V on your keyboard to activate it.
Next, simply drag the .png image over the .jpg image. Position the .png image where you want it placed in the .jpg image.
Press CTRL + S to save the file and you’re done.
This is the Move Tool.
See these images for reference.
You may also watch the video “Applying Background To A 3D Model In Photoshop”.
Wonderful mates! I loved your comments.
Before surfing your comments, I have tried whatever I can but I have failed to be successful.
But now, your step by step image tutorial helps me to combine my png file with the JPEG file, in fact I didn’t expect such kind of superb solution. Also,I need tips on applying Background to A 3D Model In Photoshop, which you have provided video tutorial that was really excellent.
As a result, for that help now I am completely free from all issues.
So I believe, one day Techyv.com will be the future leader of the technology world because all the instructions and problems can be solved in this site by asking the techyv experts.
Thanks guys as well Techyv too for enriching my knowledge.
