I need tips on how to use Logon Screen Changer
Hello fellow Techyv members.
Where can I download the Logon Screen Changer to change my login screen background?
How do I install and will it work on all Windows OS?
Can I use an HD JPEG image that I have?
I need tips on how to use Logon Screen Changer.
Best Answer by Sharath Reddy
Answered By 0 points N/A #141172
You can download the Login Screen Changer here.
It's easy to set up, but it only works on Windows 7.
You can use any size image as long it's within the supported image formats.
If you want a solution that works on operating systems other than Windows 7, you can get LogonStudio instead, which supports XP, Vista, and 7.
Answered By 590495 points N/A #141173
This program is somewhat similar to the one I’m using although it is only limited to just changing the logon screen and mine offers a lot more. If you are tired of seeing just the same screen every time you log in to your computer, then Logon Screen Changer will definitely change the screen you see.
If you think you can change the logon screen without using any tool, I think it won’t be possible because Windows doesn’t provide any option of modifying the logon screen just like changing the desktop’s wallpaper.
This is the sample screenshot of the program.
This program can modify the logon screen and replace the blue background with your desired image. Logon Screen Changer comes with its gallery of images that you can apply on your logon screen. You can also download images or maybe create one your own as long as its size is smaller than 256 KB.
This application is limited to Windows 7 only. To download, visit Download Logon Screen Changer. You may also watch “How to use Logon Screen Changer: Change your login screen background! | TechyV”.
[video:http://youtu.be/lrvBlBTs6wM]
Answered By 20 points N/A #141174
Hello fellows, your explanations were very commendable.
Both of you have given perfect solutions. From your post, I have obtained an idea that without using any tool I cannot change the logon Screen, for that I needed to download images or create my own images of a size that is smaller than 256 KB but this application is only for Windows 7 which is the one I am using now.
Guys, downloading from your provided link and watching your video tutorial was a very nice way to solve my problems.
Now I am able to change my logon screen background. Thank fellows especially to Sharath for helping me to change this since I was tired of seeing just the same screen every time on my computer.
