I need tips on how to use NFOPAD
Hi.
I have an NFO file which I cannot open.
I plan on using NFOPAD for opening NFO files.
I need to know the media and product information of a certain media file.
Where can I download NFOPAD?
Hi.
NFOPad is a quite easy to use program.
You just open the NFO file with it, and it tries its best to display it correctly, including its character encoding (it has support for ASCII, ANSI, and Unicode). It also displays ASCII art correctly, can be portable, and is highly customizable.
You can download NFOPad here. There you can pick if you want the installer or the portable version.
Compared to note pad it throws in some extra fun and useful options to make NFOPad versatile. Major difference is menu bar in notepad is replaced by settings bar in NFOPAD. It installs and uninstall without any problem. visit this link:
NFOPAD has in built ASCII fonts for NFO
NFO files use the extension “.nfo” and cannot easily be opened by simply double-clicking on it. Because if you do, it will open the System Information window of your computer instead of opening the actual “.nfo” file. Actually, “.nfo” files are all simple text files that only use a different extension name. NFOPad is a program that includes the basic functions of the usual Notepad text editor plus added extra features that are not available in Notepad like added support for NFO files.
The actual user interface of NFOPad is very similar to that of Notepad and their only difference is in the Format menu. In NFOPad, the Format menu has been replaced by Settings menu. In addition to its functions, if the NFO file contains links, this program will allow you to follow those links which is not available in Notepad as well as in AkelPad.
You can also decide on the tab size, customize the text and background colors, set auto-width parameters, and more. If you are interested with NFOPad, you can download it. It supports Windows 2000, Windows XP, Windows Vista, and Windows 7. You may also watch the video “How to read .NFO files using NFOPAD | video tutorial by TechyV” to know more of its features.
[video:http://youtu.be/nvgapbjSQHU]Notifications
