I need to know how to remove google contacts for privacy reasons.
Hello! I have my doubts about breaches in the privacy of my accounts and hence, for security purposes, I would like to remove all contacts from Google.
How to remove google contacts using my smartphone? Please answer ASAP. Thank you!
Best Answer by
Answered By 0 points N/A #330659
There are multiple ways in which you can delete your Google contacts from a smartphone. Here is how to remove google contacts using a smartphone.
Navigate to contacts.google.com. Your contacts will be displayed here. When you hover over the required contacts, the profile picture will turn into a checkbox, which you can check. From “Selection Actions,” you can select all the contacts and choose to Delete them from the “More options.”
Otherwise, go to the Contacts App. Press and hold each contact you want to delete and select the Delete option from the three dots arranged vertically. If your contacts are synced to Gmail, they will get deleted.
Hope it helped!
