I need a tool for viewing EML on Linux
Hello everyone,
I am using Linux. I want to view EML in Linux. So I need a tool for viewing eml Linux, but I can't download it. Please give me some links.
Hello everyone,
For windows operating system, you can use Kernel EML viewer to view EML files. For Linux, you can use Linux EML viewer software. It is a useful tool for viewing EML files in Linux OS. You can download the software from this site :http://linux.software.informer.com/download-linux-eml-viewer/
Enjoy the tool.Thanks.
Hello, Dominique
Hope you are fine.
EML Viewer v.10.09.01 is an EML viewer tool. It allows you view EML file. It works even when Outlook Expressed is not installed on your computer. I work on XP, Vista, Windows 7.
You may try this link for more.
Hope you will get your answer.
Notifications
