I need a touch player update for HP Touchpad
Good day! It seems that my touch player for my HP Touchpad is outdated, I wish to have a touch player update hp compatible but I'm having trouble finding such. I am seeking an expert suggestion regarding this matter. Thanks.
Best Answer by Marvin M Calderon
Answered By 55 points N/A #133263
Hello Lark Yency,
                  If you want to make your touch software working then you need to go to the help menu from there you need to go to the trouble shoot menu from there you can find out and can fix the errors in your software. But still if you do not get your software in working condition then you can get a version from the below link. Software named as "VLC player" you can download it from the below link and can enjoy your touch player.
http://softwaretopic.informer.com/vlc-media-player-on-hp-touchpad/
Answered By 0 points N/A #133264
Hello Lark,
Touch player has been known to have compatibility issues with regard to some media formats. I would like to recommend that you install another media player that is compatible with your HP touchpad. You can choose to install Kalemsoft media player which is for now the best HP compatible media player. It costs 5.99 dollars. If you prefer to use a free media player then VLC is the best and you can download VLC for HP Touchpad from software informer. To get it click on this link http://softwaretopic.informer.com/vlc-media-player-on-hp-touchpad/
