Hello
,I have the old 330 which is running on my isp with no problem. Just recently, l installed vista. Then upgraded my 330 drivers online, and it went well. But now that l have windows 7, my 330 doesn't work, l need to upgrade my drivers once more via online with a bit speedtouch 330 driver win 7 I guess.
Can anyone please tell me where could this be done?
Thank you.
I need to upgrade drivers with a bt speedtouch 330driver for win7
Hi Kylie
I have had this problem before and  i recommend using A program called DriverPack Solution. Its an easy  and fast program to find any driver pack you want what ever new or old driver and you can do it from almost  one click.
You can download it from here.
But if you want this specific driver only , i have to tell you that there is no official one yet although i can give you away to make it so follow the steps :
Download the "SpeedTouch330seriesR4.0.0.5.exe" from here and run it.
When it freeze searching go to the device manager.
Update your driver automatically ( Must be installed ).
If it didn't create connection you have to create it manually by going to start menu then run this "rundll32.exe netshell.dll,StartNCWÂ " Â Click on it.Â
Hello Kylie Caseey,
 If you want to update your drivers then you have to go to the manual way and you have to download the file of the driver. But in Windows 7 there is an automatic system that if you attach any of the device than it searches online for the driver and make it available for you. So connect your PC with internet and after that attach the Bluetooth device to the PC. But if you still do not get the device in working condition then you can get it from the below link.
http://download.cnet.com/Bluetooth-Software-Ver-6-0-1-4900-zip/3000-2108_4-162222.html
