I need VM assistance please help
How does a VMM work by assigning system resources to each VM?
How does it work for a VM to execute one simple task and also over multiple tasks?
Any VM expert there?
As you must be aware that VMM is a server application created by Microsoft to manage a virtualized data center to rum the virtual servers, functioning to:
Consolidate physical servers, Rapid provisioning of new V machines, conversion of machines from physical to virtual through wizard (P2V) and conversion of Virtual machines to VMware virtual machines (V2V).
The concept of VMM is to explore the Virtual server cloud by very quickly accessing the different data and information.
You must visit the link to get a glimpse of how this can be done and the link is: (Real Player or VLC Player needed)
As it is a control center for very server, each command can be performed and also audited through a tab called “ JOB”, when you click on the job, multiple options get available to the administrator, which the administrator can run through the VMM, and such commands get executed centrally.
Same, console is used to assign the different resources to the particular VMs.
I further advise to also go through the tutorial available on the following link, which will interactively provide this information:
Regards.
