Hi everyone. I just installed Puzzle Pro 2.0 plug-in for MS Paint. Paint is now inaccessible as it constantly crashes after the install. Is there any workaround for Puzzle filter Paint? I'm on a Windows XP 64 bit system. Thanks in advance.
I need a workaround for Puzzle filter Paint
Hi Douglas,
MS Paint is not a compatible host for Puzzle Pro 2.0 plug-in. Â Compatible application programs for Puzzle Pro 2.0 are Adobe Photoshop, Paint Shop, Macromedia Fireworks, and Ulead. MS Paint and Paint Shop are both application programs used for editing photos but, they differ by degree and availability of tools. MS Paint comes with simplicity of tools when editing photo images while Paint Shop uses sophisticated tools and graphics for editing.
You have two options:
Download and install a compatible host program for Puzzle Pro 2.0 plug-in for Windows:
Adobe Photoshop (7.0, CS, CS2  – CS5)
Adobe Image Ready (2.0 and higher)
Adobe Photoshop Elements (1.0 and higher)
Adobe Fireworks (MX and higher)
Corel Photopaint (8 and higher )
Corel Paint Shop Pro (5 and higher)
ACD Systems Canvass Professional 8.0.1
Ulead Photoimpact (8 and higher)
2Â Uninstall Puzzle Pro 2.0 plug-in. Download and install the updated version Puzzle Pro 3.1 plug-in as well as a compatible host application for the plug-in(above choices).
