I need writing lines software
Hi Everybody,
Can you help me to find writing lines software, I used Microsoft word 2010 to make lines for my child, but i need a professional software with smart features
Thank You.
Hi Everybody,
Thank You.
Hi Mehdi42ai,
I have read your problem. You did not mention what kind of writing line you need. If you would do that it would help me. However there is lots of software in the web which can help you.
1) Go to Google.com and search for your software. For writing Microsoft word is best.
2) If you want customize line then Microsoft paint can help. It is a program for painting.
3) Adobe illustrator is another software that can help you. It is basically a designing software. But is hard to learn.
4) You can also use Microsoft excel. It is another software produced by Microsoft which helps in calculation.
Hope you will find your desired software.
Regards
Hi Mehdi42ai,
This is very funny that you ms word as useless software to write. Because there are millions people out there using this software as professionally. But if you don’t then we should help you to try another. I am going to suggest you two more and they are:
First one is a open source and second one is online based and most secure plus free.
Hope you will get better result. Good luck.
