I need your help uninstalling Clear.fi
Will you help me uninstall clear.fi from my laptop.
Ii do not want this program on my laptop.
Please help me.
Please help me.
Yes, the program clear.fi is giving problems while uninstalling it. So I would suggest you to use softwares that help in removing these kind of stubborn program.
You can use Revo uninstaller or IObit uninstaller. These will permanently delete clear.fi.
But don't worry, once you delete the program, you can download it again anytime free of cost from the acer website
To remove or uninstall the clear.fi program you have to do few things. At first you need to download the windows removal tool then install it. Now close all the related files or folders and run the windows removal tool which you installed. After that highlight it in the ‘display name’ list and then select the uninstall option to remove it completely. Hope this could be a help.
Good luck.
Notifications
