Hi to everyone,
I need your suggestion on a strong and effective antivirus.
There are so many kind of viruses all over the internet and just waiting to be downloaded to attack your system.
I need a strong and reliable antivirus that will kill those worms that are very harmful. I got so many important business files that needs to be protected.
In addition, my operating system is windows 7 starter 32 bit.
Thank you.
Hi Brenda Lopez,
If you try to find best antivirus for windows 7 answers would be Bitdefender, Kaspersky, Webroot, Norton, and Eset.
The Bitdefender is on the top place so you may consider trying this antivirus on your Windows 7 OS computer.
Bitdefender is really effective on removing, blocking, preventing, and neutralizing infections. It has also the top review on great performance, features, and help support.
Hope this information helps.
Hi Brenda,
I will help you to choose a good and effective antivirus. On Windows there are several effective antivirus programs exist.
Norton 360, Symantec Endpoint, Avast, Kaspersky, McAfee, Panda security and a lot more good and effective.
You can choose any one of these to get secured from viruses.
On Windows, there are more than a million virus. Use of antivirus is a must.
mcbrel
Hi,Â
If you are looking for best Antivirus, I suggest this Antivirus software BitDefender Antivirus and Kaspersky Antivirus.
This is the top two Antivirus .
This is compatible with Windows 7 that you currently using.Â
I also suggest this Antivirus software,
Webroot Antivirus
Norton Antivirus
ESET Antivirus
for free Antivirus software try this,
Hope this helps you find best Antivirus for your PC.
Goodluck!
There are different antiviruses, that you can get free or can buy.
I suggest you two of them from there
1. Kaspersky – You can buy it or can use free version of that. If you want to get it, visit this link
Here you will get the free version of kaspersky or can buy it. I think it is the best antivirus. Because you will get regular update of it and it will protect your data from damage that occur due to virus attack.
2. AVG – You can also use AVG antivirus. It is also good for PC's of home and business. You also can use it's free addition or can buy it.
