annaatutor
40 points
Posted on - 04/03/2013
Where can I get zen cart pdf invoice control panel downloaded? I need the program which will give me the mentioned below as well as the possibility to export products from my list to MySymon.com, preferable with minimum clicking or manipulations. Please advise which software will be the best on your opinion.
I need zen cart PDF invoice control panel software
Hi there,
Zencart has a default ZC order processing in admin>>customer>>orders which prints out HTML files instead of pdf invoices. Pdf order center is a good pdf invoice control panel. Pdf order center allows you to-
1) Process multiple orders at a time.
2) Create a unique invoice number.
3) Customize your invoice from the control panel.
4) Update and delete order.
You can download PDFOC here.
You can download easy populate to export products from a list to your site. Download here.
