Micah Nandy
Posted on - 04/11/2013
Hi expert,
I have installed sparrow lite software with Gmail on my PC. I have some problem by using this software. But when I perform to uninstall sparrow lite after uninstalling still some files are remaining on my PC. How can I solve this problem?
I perform uninstall sparrow lite and after uninstalling still some files remaining
Hello Micah,
You can download Perfect Uninstaller here.
You may also do it manually by deleting all files in that folder and deleting it's contents in the registry.
This is how you do it:
Press windows key type in CMD.
A black box should appear type regedit in that box and press enter.
Select HKEY Local Machine
Select Software
Delete Sparrow Lite
Sincerely,
Luz M Terry
Hello Micah,
If there are still parts of any program after you uninstalled it, install CCleaner and run, it will delete any files that are not connected to any other program that you have used before. I had the same problem and CCleaner helped me it.
You can also use any other program similar to CCleaner – antispy program that will help you get rid of any files that don't get deleted when you uninstall programs.
Best,
Moses
Greetings Micah!
For complete removal including all files and registry keys left by uninstalled programs, you could try Revo Uninstaller. It lets you uninstall any program or software in your computer with no complications. It does more than your usual Add/Remove Programs in the Control Panel because it also deletes and wipes everything that is related to that software in the registry and files left by it. The program is paid software but has a 30-day free trial.
