I have an Apple iPhone and I am having some trouble dealing with different features on it. It will be real easy for me if there is a file manager for that. I would refer the best one in the market.Â
I would also like other methods by which I will be able to see different application installed, different file types etc.
Please help me with this problem.
Karlos Hilton
I-Phone manager need-best one in the market
You are asking about the iPhone manager software on your iPhone. This helps you to arrange properly your files and data. So, that you can easily identify your data and reach the desired file whenever you wants.
I have given you 2 links where you can find the best software for your iPhone.
You have to visit these pages for different file managers.
https://www.pcworld.com/article/234357/xilisoft_iphone_magic.html
I am sure these managers will work accordingly to your desires and fulfill your desired requirements also.
Here it is a variety of managers is given you can now easily search and choose your required.
This will resolve your problem.
Thanks
