I Receive “Connection Failed: Peer Could Not Be Added” When I Try To Join A World With “Play With Team”
Susan Walker 40 points N/APosted on - 05/28/2019
In Fallout 76, I tried joining a world using the “Play with Team” option. But every time I do this, I receive the message “Connection failed: Peer could not be added” and I can’t join a world. Is there a way to fix this or another way so I could join a world?
The full error reads “Connection failed: Peer could not be added”. You normally receive this error when you try to join a world with the “Play with Team” option in Fallout 76. To fix the problem, log out of the game and exit the Bethesda.net launcher. Right-click the Bethesda.net launcher on the system tray and select “Quit”. After this, launch the game again.
Try also restarting your router. If the router has a power button, press it to turn it off then unplug it from the power for about ten to twenty seconds (10 – 20). Press any button on the router to drain any leftover power or to power cycle. After this, plug the router back to the power and turn it on.
1....
