I installed “Fallout 76” just last night and the game was perfect. I was able to do some missions. After playing for a couple of hours, I ended the session and turned off the computer. Today, when I tried to start the game, the game launcher started normally then after a few minutes it displayed the message “Connection failed: Timed out while waiting for server to respond”.
Fallout 76 – Connection failed: Timed out error
I tried again after a few minutes but the same message appears. How do I fix this?
This error is normally an indication that the server is down for maintenance and this is normal. This happens on a regular basis on every online MMORPG games not only Fallout 76. The downtime normally lasts for only a couple of hours. This is the time when they usually patch the game for the start of new season aside from the usual maintenance activities.
Fallout 76 MMORPG
If the Bethesda.net launcher indicates that the servers are online, try checking the following:
Bethesda Support – visit their Twitter account to see if there is any planned maintenance or outage
Bethesda.net Server Status – go visit their server status portal to see if there is any planned maintenance or outage
Xbox Live Status – if you are playing via Xbox, check the Xbox services
If the servers are up and you are still receiving the message, completely log out of the game and close the Bethesda.net launcher. Restart the computer then launch the Bethesda.net launcher again. Navigate to “Fallout 76” then click “Game Options”. Next, select “Scan and Repair” then wait until it is complete. If this doesn’t work, try to disable your antivirus or firewall temporarily.
Try also restarting your router. If the router has a power button, press it to turn it off then unplug it from the power for about ten to twenty seconds (10 – 20). Press any button on the router to drain any leftover power or to power cycle. After this, plug the router back to the power and turn it on.
If the problem continues, make sure to exclude or whitelist this folder in your antivirus or firewall: “C:\Program Files (x86)\Bethesda.net Launcher”.
1....
