abigail.era
Posted on - 08/27/2012
I have a DVD disk in my Drive but I receive an error from my RealPlayer SP Plus software saying there is “no disk in drive” when trying to burn a DVD. Why do I need a high powered PC to use Real Player SP Plus?
They should be telling customers if this is the case.
Dear Abigail,
Real Player has the following system requirements:
http://pk.real.com/overlay/sysreq_rp14.html
Please check to see if your computer has sufficient specifications. It is not a very resource heavy software, though compared to other similar softwares it does take up a lot of room.
Also, check if you have the latest version of RealPlayer.
http://pk.real.com/?mode=rp_plus
This link will take you to the download page.
If none of the above fixes the problem then either your DVD is in bad condition/scratched up rendering it unreadable or if the DVD is fine your DVD-ROM may be starting to give up…
It might be a good idea to get it checked or even replaced.
