I receive an error when I try to convert “x.mesh” to “x.obj”
I receive an error when I try to convert “x.mesh” to "x.obj".
Error
Error loading ShaderTech "T000" in Shader "Blend".
OK
Can you help me?
Error
OK
Can you help me?
While converting “x.mesh” to "x.obj" an error report Error loading Shader Tech “T000” in Shader “Blend” arises as it requires some more updated files for conversion that is not available in your installed software.
To solve this problem you need to update your program using to convert “x.mesh” to "x.obj". Turn on your Windows “Automatic Update”. Connect your PC to the internet. This will update your existing software automatically. You can also visit the website: https://wizualizacje.weebly.com/digital-art.html.
Through this link you can also make the software updated. Now the conversion will be continued and such error message will not appear any more.
I hope you understand it.
Hallo Ashley,
Have you successfully used the converter before or you have been getting that error since you installed it? If the application has been working just fine, the error that you are getting could be as a result of the following reasons:
Carl
