I just installed Fallout 76. Installation works fine and I didn’t receive any error. After installing the game, I logged into the game to see how it looks like from the inside then I log out. I saw an available Windows Update on the system tray so I installed it then restarted the computer.
Fallout 76 – This account is not authorized
After an hour or two, I tried playing the game again but this time a message greeted me saying “Login failed. This account is not authorized”. How do you fix this?
I Receive “Login Failed. This Account Is Not Authorized” When Logging Into Fallout 76
If you are unable to access Fallout 76 or you can’t log into the game, one possible reason is that you haven’t redeem the retail game code yet. Note: the retail game code is different from the B.E.T.A. code you may have previously redeemed on your account.
If you purchased Fallout 76 digitally via Bethesda.net Digital Store, Xbox One Marketplace, or PlayStation Store, you don’t need to redeem the retail game code manually because it will be applied automatically to your account. This should immediately allow you to launch the game. On the other hand, if you purchased the game from another participating retailer, please contact your retailer how to get the retail game code.
If this doesn’t work or you already redeemed the retail game code on your account, try using the “Scan and Repair” tool. Completely log out of the game and close the Bethesda.net launcher. Restart the computer then launch the Bethesda.net launcher again. Navigate to “Fallout 76” then click “Game Options”. Next, select “Scan and Repair” then wait until it is complete.
If the problem continues, log into your Bethesda.net account with a web browser and contact Bethesda Customer Support.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
