I Receive “Vault-Tec Engineers Are Hard At Work Getting Our Servers Back Online! (NoRegionPing)” When Starting Fallout 76
karamhobbs 20 points N/APosted on - 05/14/2019
I don’t play this game regularly but I do play it when I have nothing to do. The game works perfectly OK the first time I install it. But one or two days ago I started receiving “Vault-Tec engineers are hard at work getting our servers back online! (NoRegionPing)” whenever I start the game and I can’t play it anymore.
Fallout 76 NoRegionPing error
If you have any idea how to fix this, please help.
The game “Fallout 76” has received a tremendous amount of negative feedbacks from game review websites and players alike. If you receive “Vault-Tec engineers are hard at work getting our servers back online! (NoRegionPing)” when you start the game, exit the game then restart the computer. After booting, temporarily disable your antivirus or firewall then try launching the game again.
If this worked, you need to whitelist two game files:
Fallout 76.exe – located in “C:\Program Files (x86)\Bethesda.net Launcher\games\Fallout76”
BethesdaNetLauncher.exe – located in “C:\Program Files (x86)\Bethesda.net Launcher”
Add the files “Fallout 76.exe” and “BethesdaNetLauncher.exe” to your antivirus, internet security, or firewall’s exclusions list so they will be ignored. If you are using Wi-Fi connection, try switching to wired connection and vice versa.
1....
