I received an error message that ITunes Store is temporarily unavailable
Hi
I will certainly help you in this problem. The error, iTunes Store cannot be found is shown when there is an error in connection you using or when the iTunes store is down for maintenance. Try again later so that it could be available to you. The iTunes Store is not available in some countries so check your country first.
Hello Adolfojeremiah,
Try these steps and see if it works.
– Please check if you are having problems with internet connectivity. You might be experiencing unstable connection. Check your connection and try again.
– Please check if you are using an updated version of itunes. Older versions tend to become unstable once a new version comes out.
Hope this helps.
