While trying to download Norton Remove & Reinstall tools from the website I received an error message. The error message directed me to visit the Norton remove and reinstall website as directed by the error message to get more information regarding this error. However, I am unable to get any idea about installing this new tool.
I would request you guys to help me solve it.
I would be much grateful.
Could not download the installer layout. Click here for
information on how to uninstall and reinstall your Norton product
manually.
I received an error message while downloading Norton Remove & Reinstall tools
Hello Martin,
First I would suggest you to download and run Malwarebytes. If everything is clean then it might be possible that certain condition could have arisen and you must re-install the program. You must follow the instructions to reinstall the program.
1- First you must export all of your credentials and identities used in Norton to your desktop.
2- Always make this sure that you have already set the Norton account.
3- Using Control panel uninstall your Norton software.
4- Download and instantly run the Norton removal Tool just to make sure it is completely removed.
5- Restart your computer. Log in to your Norton account and download again.
This might help you.
