I received an error message while exporting my video through Squeeze
Failed – encoding: Communication with external compression process failed, TRequest::TRequest(“SMAceEXternaljob::getProgress”),
Timeout 5000 msec
Timeout 5000 msec
Hi Aldo Dillan,
Thanks for sharing your problem with us, you can solve this problem by running compression "in-process" mode. To run compression "in-process " mode follow the following steps:
1. Go to Preferences.
2. Click on 'Advanced' tab.
3.Uncheck 'Run jobs in a separate external compression process'.
I hope this will help you.
Hi Dear,
Thanks for sharing your problem with us.
I hope we shall be helpful for you.
Squeeze is an animation studio that helps you to Manipulate your video as you desire.
First assure that the file type you are exporting is correct or supported by Squeeze?
Because the file types that squeeze can input into itself are large then exporting file types.
So Kindly check your exporting media file that is it supported by the squeeze.
If it is supported then 2nd thing is to check the output "Frame Rate" , "Frequency" , "Streaming Quality" etc.
Some files can be exported Uncompressed and for some file types it is necessary to Compress them
Kindly check it.
You will Minimize this problem very easily.
Regards….
